Nokia PureView 808 z aparatem 41Mpx
Postprzez lizard-borys » 27 lutego 2012, o 13:32
Cena okolo 450euro
Dane techniczne:
Size: 123.9 x 60.2 x 13.9 mm (17.95 mm at camera)
• Weight (with battery): 169 g, Volume: 95.5 cc
• 16 GB internal user memory
• Support for up to 48 GB with an external microSD memory card
http://www.youtube.com/watch?feature...&v=vfvMWyWvrAQ
Aparat:
• 41 megapixel camera sensor with Nokia PureView imaging technology and Carl Zeiss optics
• Fullscreen 16:9 viewfinder with easy on-screen touch controls
• Xenon flash with operating range up to 3.5m, depending on conditions (double the range of the N8's flash)
• LED for video recording
• Lossless zoom: 3x for stills
• Focal length: 8.02 mm (35 mm equivalent focal length -26 mm, 16:9 / 28 mm, 4:3)
• Auto focus and touch to focus
• Focus modes: Hyperfocal, Macro, Infinity and Auto
• Focus range: 15 cm ~ infinity
• Macro focus 15-50 cm
• F number/aperture: F2.4
• Supported aspect ratios and resolutions True 16:9 (2 MP, 5 MP [Default], 8 MP, 34 MP) 4:3 (3 MP, 5 MP, 8 MP, 38 MP)
• Three shooting modes: Auto, Scenes, Creative, Face detection software
• Launch camera from lock with full press of capture key
• Video resolutions: Full HD (1920x1080) 30fps [Default], HD (1280x720) 30fps, nHD (640x360) 30fps
• Lossless Zoom: 4x1080p [Default], 6x 720p, 12x360p
• Frame rates supported: 15, 24, 25, 30fps
• Stereo High Amplitude Audio Capture (HAAC)
• Three shooting modes: Auto, Scenes, Creative, Integrated video editor for trimming video
• Screen size: 4” Resolution: 16:9 nHD (640 x 360 pixels), AMOLED, 16.7 million colours, ClearBlack display, Gorilla Glass
• BL-4D 1400 mAh high voltage Li-ion battery, user replaceable(!)
• GSM/EDGE 850/900/1800/1900, WCDMA 850/900/1700/-21001900/2100
• Bluetooth 3.0, HDMI, DLNA
• High-Speed USB 2.0 (micro USB connector), Micro USB connector and charging, USB On-the-Go
• 3.5 mm Nokia standard audio connector with TV-out
• Secure NFC
• WLAN
• A-GPS
• FM transmitter
• Talk time (maximum): GSM 11 hours, WCDMA , 6.5 hours, Standby time (maximum): GSM 465 hours, WCDMA 540 hours
lizard-borys
Dołączył(a): 4 stycznia 2009, o 11:00
Mod.tel.: n82 n6220c n73
Re: Nokia PureView 808 z aparatem 41Mpx
Postprzez maniek6600 » 27 lutego 2012, o 14:39
Aparat 41 mpx ??? A są wogóle takie???
http://pclab.pl/news48954.html
maniek6600
Dołączył(a): 19 marca 2007, o 17:16
Postprzez kolaCT » 27 lutego 2012, o 17:36
Pewnie jeszcze nie wiadomo z jakiego materiału jest wykonana obudowa?
Mi osobiście design nie przypadł do gustu, a szkoda bo powoli zaczynam się rozglądać za godnym następcą N8...
kolaCT
Dołączył(a): 25 lutego 2009, o 01:14
Mod.tel.: N8-00 + E66
Postprzez dpatryk » 27 lutego 2012, o 23:19
a wystarczylo tylko ten fon zrobic z WP i ludzie bardziej by chetniej " sprawdzali " mobilne okienka
a tak taka lumia 900 absolutnie mnie nie przekonuje do siebie
ogolnie jakos WP mnie odstrasza ...
system niemalze zalezny od posiadania komputera w domu cos jak AJFON hehe
jak narazie wp MOWIE NIE :)
symbian staruszek coz
andek to juz wogole nadreklamowany system
i co tu brac
dpatryk
Dołączył(a): 26 listopada 2006, o 02:20
Postprzez nismo » 27 lutego 2012, o 23:53
Design dyskusyjny ale wnętrze cudowne. Nikt nie spodziewał się, że Nokia zaprezentuje aparat z taką ilością megapikseli. Liczyłem mimo wszystko, że Nokia 808 PureView będzie wyglądem przypominać telefon Nokia N9 lub Nokia Lumia 800 czy Nokia Lumia 900. Jednak dla tego aparatu jestem w stanie przeboleć wygląd.
Postprzez mico11 » 28 lutego 2012, o 12:56
tylko dlaczego jest taki gruby jeśli nie ma optycznego zoomu ??
no i po co fizyczne klawisze słuchawki jesli tez są ekranowe ? mogli pomniejszyc trochę ramkę wokół ekranu od góry i od dołu... ogólnie wzornictwo sprzed 3-4 lat... dlaczego ciągle ten sam przestarzały procesor? za słaba bateria powinno być minimum 1600mah, duży plus niewątpliwie za diodę i ksenon :)
-- 28 lutego 2012, o 13:02 --
dpatryk napisał(a):symbian staruszek coz
i co tu brac
n9 ? :)
Postprzez jędrek18 » 1 marca 2012, o 19:39
Jest gruby, bo musieli gdzieś upakować taką ogromną matrycę. Zoomu optycznego nie ma, ale jest cyfrowy, który działa bezstratnie (różne powiększenie zależnie od rozdzielczości).
Procesor nie jest stary, to prawdopodobnie ten dwurdzeniowy Broadcom: http://komorkomania.pl/2012/03/01/uklad-broadcom-z-videocore-sercem-nokii-808-pureview
Poza tym, z tego co wiem, Symbian nie potrzebuje ekstra wydajnego procesora by działać szybko.
Design bardzo przypadł mi do gustu, przypomina starsze N-ki. Sam posiadam N85 i już od bardzo dawna zastanawiam się nad wymianą. Nie potrafiłem znaleźć godnego następcy. WP mnie odstrasza, podobnie jak kolegę dpatryk, Android do mnie nie przemawia. Stary, sprawdzony Symbian po odświeżeniu do wersji Belle wydaje się ciekawą opcją.
Długość pracy na baterii (wg. producenta) jest dłuższa od tego, co mam w moim obecnym telefonie (w zupełności mi wystarcza).
Z niecierpliwością czekam na pierwsze testy, wydaje mi się, że to może być mój kolejny telefon.
jędrek18
Dołączył(a): 12 grudnia 2007, o 00:13
Mod.tel.: N85 E52 E51 i N73 ME
FW: 31.002
Postprzez leo20 » 1 marca 2012, o 20:40
Procek to arm11 ten sam co w nokii 603,700,701 i 500 ale z podwyższonym taktowaniem z 1ghz do 1.3ghz, nowszy jest za to gpu
leo20
Dołączył(a): 8 lipca 2009, o 18:07
Mod.tel.: Samsung GT-5570
FW: Sony HD
Postprzez mico11 » 1 marca 2012, o 20:51
leo20 napisał(a):Procek to arm11 ten sam co w nokii 603,700,701 i 500 ale z podwyższonym taktowaniem z 1ghz do 1.3ghz, nowszy jest za to gpu
... I ten sam co w n8 i e72 czyli arm11 sprzed trzech lat... ale jesli bedzie dzialal szybko to czemu nie
    LinuxSafari
Postprzez leo20 » 1 marca 2012, o 23:47
No nie ten sam bo w starszych jest niższe taktowanie
-- 2 marca 2012, o 16:45 --
kolaCT napisał(a):Pewnie jeszcze nie wiadomo z jakiego materiału jest wykonana obudowa?
Poliwęglan z ceramicznym wykończeniem.
źródło: http://mynokiablog.com/2012/03/02/nokia ... ss-screen/
leo20
FW: Sony HD
Postprzez górnik » 15 maja 2012, o 11:13
Wiadomo w końcu kiedy będzie ten telefon dostępny w Polsce i za ile?
górnik
Dołączył(a): 18 sierpnia 2010, o 17:14
FW: 014.002
Postprzez leo20 » 15 maja 2012, o 17:25
Pewnie pod koniec maja w cenie ok. 2500zł ale to są tylko moje przypuszczenia.
leo20
FW: Sony HD
Postprzez górnik » 14 lipca 2012, o 11:09
No i stało się :) Jestem szczęśliwym posiadaczem N808. Telefon jest super, w porównaniu do N8 jakość zdjeć,wykonania jest dużo lepsza :) Niepokoi mnie tylko jedna rzecz - nie ma dnia bez totalnej zawiechy systemu...obojętnie czy jest to aplikacja aparatu, społeczności itp pomaga wyjęcie baterii.Nie wiem może jest to niedopracowanie systemu s^3 z Future Packiem 1. Ma też ktoś takie objawy?
górnik
FW: 014.002
Postprzez 321dario » 14 lipca 2012, o 15:51
czyli masz soft v112.20.310 ?moze zrob na poczatek format kodem *#7370# dziwi mnie,ze lepiej jest wykonana :] czyzby plastikowa klapka baterii byla lepsza niz obudowa z anodyzowanego aluminium :hyhy:
321dario
Mod.tel.: nokia 808
FW: v113......
Postprzez samtech84 » 14 lipca 2012, o 23:27
Też mam tą nokię i jak na razie wszystko stabilnie działa, co do jakości wykonania pomimo plastiku jest OK, chociaż brakuje metalu tego z n8
samtech84
Dołączył(a): 8 grudnia 2006, o 08:52
FW: PR 1.1
