RomPatcher Plus.v.0.8 Beta (Autostart)
Postprzez zoltan78 » 25 sierpnia 2009, o 23:15
Jest to poprawiona wersja z funkcją autostartu.
Testowane na Omni HD.
Po restarcie RomPatcher pyta się czy uaktywnić patche.
Do prawidłowego działania tej aplikacji musimy przenieść plik znajdujący sie w paczce o nazwie patcher.ldd
do folderu C/sys/bin
Od tej pory RomPatcher się uaktywni.
zoltan78
Dołączył(a): 9 lipca 2007, o 07:26
Mod.tel.: Samsung Omnia HD
Re: RomPatcher Plus.v.0.8 Beta (Autostart)
Postprzez Magik » 27 sierpnia 2009, o 17:00
Pojawiła się nowa wersja oznaczona numerem 0.9 BETA.
http://www.ipmart-forum.com/showthread.php?t=392816
*** Change-Log BETA 0.9 ***
+ Fixed: was not compatible with some devices (eg. E63). The error message "patcher.ldd not found" was shown always also after a reboot.
+ Fixed: some patches were not applied due to additional spaces in the .rmp... Now additional spaces should be handled correcly.
+ Fixed: crash when trying to patch an executable that was missing in the device.
+ Improved: better parsing of the patch file. Both windows and unix text should be handled properly, with unicode/utf8/ascii encoding.
+ New: added LoadPatch/CheckPatch/ApplyPatch logs to the Engine, to check the correct patch parsing... <-- I know these popups are really annoying, but in order to release the final verion I need to be sure that (almost) ALL the RP patches will work correctly on RP+ also.
+ Removed: autostart correctly works, so popups have been removed (however, other popups have been added to the Engine, so you'll see popups for each patch you put in autostart)
WARNING: do NOT install this version on OmniaHD because it will not work and your device will keep to reboot itself if you have some patch in Autostart...
A fixed version (compatible with ALL the devices) will be released soon.
Magik
    UbuntuFirefox
Postprzez xone » 27 sierpnia 2009, o 22:30
Autor aplikacji dyskutuje tu -> Symbian-Freak
Aktualna wersja to RomPatcher+ v0.9 (600) [BETA] i znajduje się tu -> <ciach>
Zmiany w tej wersji to:
+ Fixed: restored compatibilty with OmniaHD
+ New: added patches Open4All and Open4All_N96
Jak będzie już wersja finalna to znikną te potwierdzenia podczas uruchamiania każdego patcha..
***edit
Aktualna wersja to RomPatcher+ v0.9 (600) [BETA] i znajduje się tu -> Symbian-Freak
PS. Nie wydaję mi się żebym złamał punkt 2d regulaminu ponieważ nie jest to oprogramowanie komercyjne, a regulamin wyraźnie mówi "ZABRANIA SIĘ również podawania bezpośrednich linków do nielegalnych wersji programów lub gier umieszczonych na różnego rodzaju serwerach plików".. Autor udostępnia ten program za darmo i osobiście umieścił plik do ściągnięcia na serwerze plików. Nieważne.. Można pobrać tam gdzie napisałem.. ;)
***edit2
A tak na marginesie dlaczego zoltan78 nie złamał tegoż punktu 2d regulaminu skoro możemy przeczytać "Na forum ZABRANIA SIĘ umieszczania w załącznikach wszelkich gier oraz programów! Dotyczy to także działu z softem dla PC."? hmm..
Ostatnio edytowano 27 sierpnia 2009, o 22:32 przez szerszen240v, łącznie edytowano 1 raz
Powód: Zapoznaj się z punktem 2d regulaminu forum.
Pozdrawiam, xONE :: x01devel.ovh.org
Motto:
- Niepuszczone bąki unoszą się do mózgu, stąd biorą się posrane pomysły.
- Prawdziwi mężczyźni nie jedzą miodu... Prawdziwi mężczyźni żują pszczoły!
xone
Dołączył(a): 21 maja 2007, o 11:38
Mod.tel.: Nokia E52
FW: 052.003
Postprzez Dominbik » 28 sierpnia 2009, o 09:02
ja mam jakąś pierwszą wersję z autostartem ale działa ok a w nowej wersji zmian mało więc zostaje przy starej :P
jakie potwierdzenia ?
Dominbik
Dołączył(a): 28 marca 2009, o 23:30
Mod.tel.: N79+E50
FW: AleWKtórym
Postprzez xone » 28 sierpnia 2009, o 09:18
Dominbik, jeżeli zainstalujesz ostatnią wersję to będziesz wiedział ;)
Motto:
xone
Mod.tel.: Nokia E52
FW: 052.003
Postprzez Dominbik » 28 sierpnia 2009, o 09:29
xone napisał(a):Dominbik, jeżeli zainstalujesz ostatnią wersję to będziesz wiedział ;)
Powiedz tylko: trzeba potwierdzać autostart patcha czy uruchomienie RomPatchera ?
Dominbik
Mod.tel.: N79+E50
FW: AleWKtórym
Postprzez xone » 28 sierpnia 2009, o 09:39
Samego autostartu nie, ale musisz potwierdzać każdy patch i to 3 razy ;) niezależnie czy przy autostarcie czy jak uruchamiasz ręcznie..
Motto:
xone
Mod.tel.: Nokia E52
FW: 052.003
Postprzez Dominbik » 28 sierpnia 2009, o 10:03
xone napisał(a):Samego autostartu nie, ale musisz potwierdzać każdy patch i to 3 razy ;) niezależnie czy przy autostarcie czy jak uruchamiasz ręcznie..
ok to już na pewno wiem że zostaje przy swojej wersji jaka by nie była :P
Dominbik
Mod.tel.: N79+E50
FW: AleWKtórym
Postprzez xone » 28 sierpnia 2009, o 10:04
czekaj na finalną.. sądzę że już niedługo.
Motto:
xone
Mod.tel.: Nokia E52
FW: 052.003
Postprzez Dominbik » 28 sierpnia 2009, o 12:57
xone napisał(a):czekaj na finalną.. sądzę że już niedługo.
No mam nadzieję bo z tego co widzę to nawet te bety są dość stabilne (przynajmniej u mnie). Ja nie wiem czemu ale po prostu uważam to za świetny program i kocham ten programik (ta ikonka, przełączanie patchów itd.. :P )
Dominbik
Mod.tel.: N79+E50
FW: AleWKtórym
Postprzez xone » 29 sierpnia 2009, o 14:06
Jest już dostępna finalna wersja aplikacji v2.0
Autor prosi o zamieszczanie informacji od niego:
Il.Socio napisał(a):Warning: If you like this software then support RP+ with a donation, otherwise its development will be definitely suspended on 7th September.
http://www.symbian-toys.com/rompatcherplus.aspx
Change-Log v2.0 napisał(a):+ Fixed: The message "Application not compatible with the phone" is not shown anymore.
+ Fixed: Replaced the Open4All_N96 templove's version with wadowice's version.
+ Fixed: Sometimes the green\red patch icon wasn't showed properly
+ Improved: Touch Support, the tap will select the patch, a tap on a selected patch will apply/remove it
+ Improved: Patches can be placed in any drive, RP+ will follow the order Z: -> A: and will use the first drive which contain the \patches\ folder
+ Improved: Error messages will report the patch's name also.
+ New: Popup when launching RP+ to remember to everyone the 6th September deadline.
+ New: ApplyAll/RemoveAll options to quicly Apply/Remove all the patches.
+ New: Donate options menu...
+ Removed: Apply/Remove options have been removed because redundant. Just click on a patch to apply/remove it.
+ Removed: The annoying popups for apply patch have gone Smile yeppi!!!
+ Removed: The advanced menu' has been temporary removed, it will came back again with more options available like "Dump/View any user choosen area of memory"...
do pobrania tu -> Symbian-Freak
albo tu-> Strona domowa autora - Il.Socio
Motto:
xone
Mod.tel.: Nokia E52
FW: 052.003
Postprzez nemo333 » 29 sierpnia 2009, o 14:57
Czym to się różni od zwykłego RomPatchera? Jest sens wgrywać czy lepiej zostać przy starym?
Postprzez xone » 29 sierpnia 2009, o 16:23
Poprawione są błędy, które uniemożliwiały pracę na niektórych telefonach i wygodniej używa się go (wystarczy nacisnąć ikonkę żeby uruchomić patcha zamiast wchodzić w opcje)
Motto:
xone
Mod.tel.: Nokia E52
FW: 052.003
Postprzez Dominbik » 30 sierpnia 2009, o 09:05
Ja czekam na finalną wersję. Póki co stara działa OK.
Pozdrawiam; Dominbik
Dominbik
Mod.tel.: N79+E50
FW: AleWKtórym
Postprzez szerszen240v » 30 sierpnia 2009, o 10:31
Dominbik, przecież już jest wersja finalna. Pare postów wyżej nawet pisze.
szerszen240v
Mod.tel.: 3G 16GB E61
